20 Users Online (18 Members):
Forums >> Revit Building >> Technical Support >> applying view templates to all new views of a particular type
63 Posts No Rating |
for example , all new sections I want to have a section view template already applied. all new floor plans I want a view template already applied & so on... I used to know & cant find the solution - cheers for help
Applying and assigning a view template are two different things. Views and view templates are not automatically linked.
The best process is to assign a view template to each view that you really want to control. Then before plotting or exporting, you should highlight all sheets and pick apply default view template to views. This will assure that all views are correct as you have defined them.
If you are on 2013 views and view templates have ben re-designed to work as you are trying to do.
View Templates Not applying to view types |
Mon, Nov 1, 2010 at 10:13:36 AM
Applying View Template Globally |
Fri, Sep 2, 2011 at 3:12:13 AM
shaded with edges setting still B&W |
Fri, Sep 5, 2014 at 12:19:48 PM
View Templates and V/G Overrides, Revit Linked Files |
Sat, Jul 9, 2016 at 12:37:06 PM
Dependant View Template |
Mon, Jul 7, 2008 at 10:20:12 AM
