Forums >> Revit Building >> Technical Support >> revit and viz render?
Fri, Jan 13, 2006 at 5:19:37 PM | revit and viz render?
jrusso
4 Stars: 2 Votes
are these two a good combination for new users.
Fri, Jan 13, 2006 at 5:44:03 PM | RE: revit and viz render?
TomDorner
4.5 Stars: 25 Votes
If you are a new user to both Reivt and Viz, I would say no. If you are new to Revit, but are experienced with Viz then yes. The rendering engine inside of Revit is Accurender by Rober McNeil and Associates. It gets a lot of bad press from a lot of Revit users as not doing a very good job, but I think it does pretty well for most users. Accurender in Revit is straightforward and does nice renderings of exteriors. It lack any global illumination so on interiors it can be problematic. Viz is a very powerful program which I myself am still learning. I've taken some classes in it and let me tell you about a deep program with menus and settings that go on forever. The Revit - Viz/Max combo is where I ultimately want to get to myself. I just don't think that trying to learn both programs at the same time would work. I think it is best to learn Revit first and then move onto Viz. Tom
Fri, Jan 13, 2006 at 6:11:08 PM | RE: revit and viz render?
zanzibarbob
3 Stars: 1 Votes
I agree with Tom. I am evaluating Viz now and it is daunting. This is a very complex and powerful program but seems to be the right combination for Revit. While at AU I discussed this issue for my needs and the Revit/viz was the unanimous choice. I'm pretty familiar with Revit now so am comfrotable exploring Viz. I would not try both since rendering is not something you vitally need for your architecture. Once you get your feet on the ground with Revit, certainly try Viz
Thomas W. Hillis, LEED AP
Wed, Jan 18, 2006 at 12:20:09 PM | RE: revit and viz render?
jrusso
4 Stars: 2 Votes
Thanks for the info.
Revit render or 3ds max design render?
Sun, Jan 4, 2015 at 10:19:29 AM
Any way NOT to render a backround in Revit 2013 ??
Thu, Feb 28, 2013 at 1:00:36 AM
New Render Appearance
Tue, Jul 6, 2010 at 9:45:22 AM
Render goes ok but when i change angle - the render is black
Tue, Oct 20, 2015 at 4:38:11 AM
Render on revit
Thu, Mar 9, 2006 at 6:45:06 PM
Page generation time: 4.4197
