20 Users Online (18 Members):
Forums >> Revit Structure >> Technical Support >> Stair Schedule
5 Posts No Rating |
I'm trying to create schedules for estimating purposes. I'm currently working on a stair schedule and I'm having trouble getting the width of the stair to show in the schedule. Any tips/ideas/suggestions?
Not a problem for me. So I don't know what you are doing.
5 Posts No Rating |
I'm using 2013, trying to schedule a monolithic stair. I created the stair using the stair by component tool and did a straight run. Then I created a stair schedule, added the width parameter, and nothing came in (see image). I haven't changed anything from the default.
I would suspect it is the component stair. Those are typically unique so I doubt the width parameter will work on them.
Did you need to use a component stair for some reason?
5 Posts No Rating |
Nope, just trying out new 2013 functions. I'll try drawing it with a sketch and see if that works.
Stair Stringer Schedule |
Wed, Sep 30, 2009 at 3:41:20 PM
stair material takeoff list |
Thu, Jun 15, 2017 at 11:28:46 AM
Can not swap out one stair family for another |
Thu, Sep 19, 2013 at 12:24:19 PM
How can I create a split stair without multiple and separate stair components? |
Tue, Jan 5, 2016 at 5:32:53 AM
Stair Nosing |
Fri, Dec 2, 2016 at 2:01:57 PM
