Forums >> Revit Structure >> Technical Support >> window lines revit structure 2013
Mon, Oct 8, 2012 at 2:46:04 PM | window lines revit structure 2013
selectstructural
I have a model that was started in 2012 but now i'm in 2013.  in my plan views the window lines are hidden when i print them.  on the screen the lines are solid.  i want solid lines.  i also have the same problem for doors.
any idea how to fix this?
Jennifer Arnold
jennifer@selectstructural.com
Mon, Oct 8, 2012 at 3:02:42 PM | window lines revit structure 2013
Not sure what you mean.  Try changing your view to coordination.
Revit Structure 2013 windows 7 & windows XP Compatibility
Wed, May 15, 2013 at 1:27:10 PM
Linked CAD ducts/pipes not showing up in Revit Structure 2013
Fri, Jul 10, 2015 at 8:36:42 AM
13
Trouble with Properties Window Revit 2013
Mon, Dec 16, 2013 at 1:49:49 AM
How do I create a roof + wall combination window in Revit 2013?
Tue, May 14, 2013 at 3:29:12 PM
Connection Design now available in Revit Structure 2013
Thu, Jun 28, 2012 at 8:08:23 AM
Page generation time: 5.0771
