Forums >> Revit Building >> Technical Support >> Wall Reveals
Wed, May 19, 2004 at 12:14:51 PM | Wall Reveals
mcompton
First, how do you get a wall sweep to be two sided..meaning, I want a reveal to show up on both sides of the wall? Second, How do you get reveals to turn corners when cutting openings into walls? TY
Wed, May 19, 2004 at 10:39:26 PM | RE: Wall Reveals
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
A single reveal or sweep cannot be located on two sides of a wall as by default they are associated to a single plane. So in this case i'm affraid you would have to place a sweep on each side of the wall. Provided you have picked multiple walls when placing your wall sweep it should automatically mitre at corners providing you are using Revit 5.1 or better. Make sure your wall sweeps are associated with one another, that is don't choose "start next" unless you have finished with that series. Alternatively, you could include the sweeps in the wall type depending on how often you are using them. Hope this makes sense, Regards, Chris. Post edited on 2004-05-19 22:40:28 Post edited on 2004-05-19 22:41:58
Regards,
Chris.
Wall Reveals
Mon, Jul 9, 2007 at 11:55:45 AM
Vertical wall reveals
Fri, Jul 21, 2006 at 4:54:55 PM
Reveals for only a part of the wall
Fri, Feb 18, 2005 at 12:30:22 PM
Vertical Reveals for Running Bond Pattern
Thu, Sep 3, 2009 at 8:20:46 AM
Reveals
Tue, Aug 4, 2009 at 9:17:30 AM
Page generation time: 0.6045
