Forums >> General Discussion >> Revit Project Management >> 4 bldgs in one project
Mon, Oct 8, 2012 at 8:09:17 AM | 4 bldgs in one project
selectstructural
I have a project going out as one set that has more than 1 bldg. is it best to have 4 different models and link them all into one revit model file?  or keep them all in the same file?  in the pass having them all in one file makes the file to large to work with.
I'm not sure how to BEST set up a project like this. Any ideas?
Thanks!
Jennifer Arnold
jennifer@selectstructural.com
Mon, Oct 8, 2012 at 8:26:55 AM | 4 bldgs in one project
You don't tell us everything so I'm not sure what I would recommend.
Do the buildings have common levels?  If not then this would require you use unique level names and restrict their 3D locations.  The same is true for Grid lines but these would be more of a problem because they too must be unique.
You say it is one project.  If things like doors / windows / finish schedules are all unique to each building, then I suggest you do multiple revit projects with separate documents.  You can link them all into one project for overall site plan.
Mon, Oct 8, 2012 at 8:48:14 AM | 4 bldgs in one project
selectstructural
all the buildings have the same elevations, beam sizes, door and window sizes and details.
different grid lines
Can I dimension and tag beams and foundation in each linked revit file or do i have to do that in the combined file?
I'd like to cut the sections in the combined file so i only had to have one set of details.
I think i'm making this harder than it needs to be
right now i have a revit file called project where i have all my details and sheets. No model is in the file just linked in models.   i have linked in bldg 1 and bldg 2 which are only models.  I have taged beams and foundation in the project file for the two bldg links.  I havent been able to figure out how to get the tags to show up that are in the link files, which is what i would like.  when i link a file in all the notes and tags disappear even  when i have the vg for them on.  When i try to schedule the job in the project file ofcourse the schedules are blank.  Can i create one combined beam schedule?
there has to be an easier way to do this
Jennifer Arnold
Mon, Oct 8, 2012 at 9:24:35 AM | 4 bldgs in one project
It sounds like you are testing and learning which is good.
I'm not sure what tagging across links is like in 2013.  You really could not do this in previous links.  You can schedule across links by checking the appropriate checkbox in the schedule to include linked models.
You still haven't given us information about your system or the building sizes so we can't address how big your file might be.  If you have a 64bit system with 8gig or more, I would think this can all be in one file.
Mon, Oct 8, 2012 at 10:17:43 AM | 4 bldgs in one project
rod23
5 Stars: 4 Votes
The way it's done is to model each building in its own file, link them all into a site plan, but do all the tagging, annotations, etc. for each building in its own file.  You lose some BIM functions when linking files as you've seen.  To do common details, they need to be all 2D drafting views, then insert from file a common detals sheet where you can reference the details.
http://www.turbosquid.com/Search/Artists/Revitaoist
portion greyed out
Wed, Nov 12, 2008 at 2:18:50 PM
Linking Callouts Between Revit Models
Mon, Jun 9, 2008 at 4:04:57 PM
Just want to say hello & ask a noobes question
Sat, Apr 5, 2008 at 6:43:32 PM
Mirror Project - Revit Architecture 2013
Sat, Jan 25, 2014 at 5:41:31 AM
project standards
Wed, Feb 1, 2012 at 11:18:52 AM
Page generation time: 1.1994
