13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Current date in formula on titleblock
hi,
i would like to add a text line to my titlesheets which shows the date 10 days from the current date so the contractor knows the date he has to respond by.
is there any way use the current date in a formula on a titlesheet?
cheers
You should always search first...
Read the similar threads below for your answer.
I did. I found many post on showing the date and time, but none using it in a formula (and adding 10 days to it).
I'm assuming you can't use it in a formula.
Your problem is that Revit doesn't have any sort of string manipulation formulas and also, that the date is represented as a string (I think).
It's not possible with the available tools. You probably need to contact an API programmer to do that for you.
Planta1 Revit Online Consulting | info@planta1.com |
Is there a way to have the current date print out on the title block? |
Tue, Sep 1, 2015 at 7:32:00 AM
Current Revision Date in sheet index |
Mon, Nov 2, 2009 at 11:22:28 AM
Titleblock Date Issue |
Tue, Jan 15, 2013 at 10:41:19 AM
date and time on titleblock |
Tue, Apr 11, 2006 at 8:19:46 AM
remove time from date/time stamp in titleblock REVISITED |
Fri, Nov 7, 2025 at 5:18:37 PM
