Forums >> Revit Building >> Technical Support >> Changed Levels to Correct Shared Elevation, now how to change topography points?
Sat, Oct 6, 2012 at 1:26:06 PM | Changed Levels to Correct Shared Elevation, now how to change topography points?
ArchiN00B
ArchiN00B Avatar
4.5 Stars: 4 Votes
So my project was roughly 100' above where I needed it to be, so instead of selecting everything and physically moving it down 100' (which would screw up pads and other stuff), I followed instructions on another forum and selected the level that should be at 0' > specify coordinates at point > entered 0'. Then I selected a level > Elevation Base > Shared. That made the levels appear correctly, but now when I try to change topographic points, they are still corresponding to the old elevations... how do I make it so the topographic points correspond to the correct elevations of my levels?
I've read so many posts on this topic my head is spinning. Please help!
Thanks.
Tue, Nov 20, 2012 at 10:34:01 PM | Changed Levels to Correct Shared Elevation, now how to change topography points?
Pavan
Pavan Avatar
4.5 Stars: 3 Votes
Try using 'Spot Elevation:Relative' and select appropriate level for 'Relative Base' from the options bar.
Pavan Reddy
Revit Manager
Intelligence is not always knowing the answers, it's always asking the questions.
topography elevation base
Tue, Mar 27, 2007 at 11:34:14 PM
Selecting Topographic Points based on Elevation
Tue, Aug 7, 2012 at 3:16:32 PM
Cannot change Project Elevation Base
Sun, Jan 22, 2012 at 2:19:36 PM
Topography points Crash in Revit 2013
Wed, Oct 31, 2012 at 4:34:47 AM
Changing elevation tags to Shared Coordinates
Thu, Aug 20, 2009 at 8:59:54 AM
Page generation time: 2.1139
