Forums >> Revit Systems >> Technical Support >> Can't connect the plumbing fixtures with branch pipes in revit mep 2012
Tue, Oct 2, 2012 at 4:30:35 AM | Connect Into tool in Revit MEP 2012
kremche
Hello, to everyone who can help me or have similar problem as mine..
I'm really new to Revit MEP 2012 , but I would like to develop my knowledge in that program,so I can start using it in my
projects.
Righ now I'm doing a project where I have to do a plumbing systems,and so far I've designed one part of the sanitary
plumbing system,but I got problem with the connection of each plumbing fixture with the branch pipes.Could someone
help me out and tell me why the option of Modify/Piping systems and more particularly Layout/Connect Into doesn't show
up on the toolbar ?
I tried to change the plumbing fixtureS in the model and re-load them this time from REVIT MEP,and then the option has
appeared,but they are not the same type that I want to use in my rpoject,also there are not many choices for family
components.  What would you suggest me ? How can I do the connections by different option or maybe I don't work
in correct way ? What do you think ?
I hope guys, you can help me,cuz the project consists of doing all different pipe systems with cold and hot domestic water,
rainwater and drainage wastewaters, soo it will save me a lot of work and efforts ,if I find the options (or at least
understand why it doesn't work for me),so Revit can make the connections automatically with all needed pipe fittings.
Thank you in advance!  Smile
Best regards,
Krem
Edited on: Tue, Oct 2, 2012 at 6:16:12 AM
Revit MEP 2012 - Linked Cad Lines being trimmed by Revit Plumbing Fixtures
Mon, Nov 7, 2011 at 12:54:25 PM
REVIT MEP 2012 Demo Phasing Disconnecting Pipes
Wed, Jul 18, 2012 at 12:20:02 PM
need some help
Fri, Oct 2, 2009 at 12:08:39 PM
Connecting 3 Pipes
Mon, Jun 28, 2010 at 11:25:05 AM
TRIMMING PIPES - MEP 2012
Fri, Sep 21, 2012 at 9:06:37 AM
Page generation time: 1.6067
