Forums >> Revit Building >> Technical Support >> Please help.. How to separate floor?
Mon, Oct 1, 2012 at 12:15:40 PM | Please help.. How to separate floor?
PChanyanatya
Could you know how to separate the floor to 2 diffrent plate? i mean if i draw one large floor plate and want to separate some
of it to the different not change only material but including level and kind of structure so how can i make it?
thank you for your kindness!!
Mon, Oct 1, 2012 at 12:40:36 PM | Please help.. How to separate floor?
Edit the sketch of the floor - copy all linework to clipboard, then get rid of the half you don't want, add closing lines and finish the edit.  Now create new, paste in your copied sketch, get rid of the other half, add closing lines and finish.  Change the idividual floors to the proper floor types.
Mon, Oct 1, 2012 at 3:00:49 PM | Please help.. How to separate floor?
TKennedy
4 Stars: 8 Votes
I generally forget to copy to clipboard the original sketch lines, so I've been copying the floor (or ceiling/extrusion/etc.) to the same place, then editing the sketch of each of the floors. It's a couple more steps than WWHub's method, but it does help when your memory is as poor as mine.
Help! Need separate plan for floor patterns!
Fri, Jul 6, 2007 at 8:12:57 AM
Saving Elements to Separate Files
Thu, Feb 18, 2010 at 4:00:28 PM
Is it possible to separate metal and glass doors swing color in floor plan?
Mon, Sep 25, 2017 at 5:34:13 AM
Need separate clean plan to add floor pattern ONLY to it.
Tue, Jul 10, 2007 at 1:02:01 PM
floor finishes
Thu, Jul 1, 2010 at 7:19:37 AM
Page generation time: 0.6559
