Forums >> Revit Systems >> Technical Support >> Dimension Mystery - What gives?
Mon, Oct 1, 2012 at 11:22:27 AM | Dimension Mystery - What gives?
TimothyLiv
I have been doing some revisions and find that some of my dimensions are disappearing....partially.
I noticed a missing dimension along a continuous string.  Some dims still show but not all.  They are not hidden by me.
Please see the attachment for more clarity.
Thank you all,
Timothy Livingston
Mon, Oct 1, 2012 at 12:15:23 PM | Dimension Mystery - What gives?
Your image really doesn't tell us anything because you didn't explain it.
More than likely, your problem is user error.  Not uncommon in Revit.  When you dimension, pay attention to what you are dimensioning to as it shows up in the lower left part of the screen.  << This needs to become a habit.  Tab until you have the right object.  If you dimension to something that is later turned off or deleted, then that portion of the dimension goes away.
To Check - turn everthing on, including hidden elements.
Activate Dimension
Tue, Dec 13, 2011 at 12:53:44 PM
Dimension strings not adding up to the total length dimension string (2017)
Fri, Mar 23, 2018 at 1:33:58 AM
Dimension Text [ 1 2 ]
Tue, Jul 8, 2008 at 9:15:07 AM
18
"EQ" dimension on either sid eof a fixed dimension [ 1 2 ]
Sun, Aug 24, 2008 at 12:08:50 PM
15
Dimension Question
Wed, Nov 23, 2011 at 11:41:34 AM
Page generation time: 1.5549
