Forums >> Revit Building >> Technical Support >> How can I model this shape? I'm out of ideas
Sat, Sep 29, 2012 at 8:11:44 PM | How can I model this shape? I'm out of ideas
emorell96
Well, I'm trying to model the shape showed in the image (the central skylight), sadly though, I haven't been able to model it, I don't even know where to start. I tried with Mass but I'm not been able to get there, I get similar results although quite different from the one in the picture. That's why I dicided to start this thread, because I'm seriously out of ideas. Thanks a lot for the help in advance Smile
Sun, Sep 30, 2012 at 5:12:11 AM | How can I model this shape? I'm out of ideas
4 Stars: 205 Votes
Adaptive Components - Check out this guy (Zach Kron): http://buildz.blogspot.pt/
Sun, Sep 30, 2012 at 10:54:09 AM | How can I model this shape? I'm out of ideas
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
See illustration.
Edited on: Sun, Sep 30, 2012 at 10:55:32 AM
Planta1 Revit Online Consulting | info@planta1.com
Sun, Sep 30, 2012 at 2:21:35 PM | How can I model this shape? I'm out of ideas
emorell96
Thanks so much for both of the answers, I researched now a bit more on Adaptive Components and I think I'll get the hold of it it after a few tries, thanks (that's what I love about Revit you can try and retry as many times as you want with even worring about damaging your project).Thanks a lot for the illustrion I'll try it out right now and tell you you how it went but it looks amazing, again, I thank you guys so much. Smile
Sun, Sep 30, 2012 at 2:58:39 PM | How can I model this shape? I'm out of ideas
emorell96
Well I tried to do what you did in the illustration but I ran into a problem, I got this message: "Unable to create form element", I probably did something wrong but I can't tell what I did wrong.
Sun, Sep 30, 2012 at 4:53:56 PM | How can I model this shape? I'm out of ideas
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
Do one half first, then the other. Revit won't be able to do both halves at once if you select the 3 curves.
Sun, Sep 30, 2012 at 5:08:12 PM | How can I model this shape? I'm out of ideas
emorell96
Ah, alright, I did it and it worked thanks a lot for your help Smile
Shape handles
Tue, Jul 8, 2008 at 10:57:18 AM
Roof Shape Handles
Fri, Feb 6, 2015 at 10:28:04 AM
using revolve tool to shape top of walls 'Revit 2012'
Wed, Feb 20, 2013 at 2:47:55 PM
'forms' not available in 'in place mass' or components.please help
Fri, Aug 30, 2013 at 3:20:58 AM
Help- floor pattern not showing up in plan, only model??
Sat, Apr 1, 2006 at 8:56:46 AM
Page generation time: 0.7479
