Forums >> Revit Building >> Technical Support >> Nested Revit Window vertical Alignment
Fri, Sep 28, 2012 at 4:22:49 PM | Nested Revit Window vertical Alignment
mcapri92
I am fairly new to revit and trying to build window families with nested sashes which can be easily switched out.  I have built a few of the sashes based off of a generic model component.  When I insert the sashes I can align them veritcally, horizontally, and centered in the frame.  However, when I switch sashes out (using the type parameter) I cannot adjust the window height or the default sill without the vertical constraint breaking or having to be broken.  I have attached the file because I am sure my lack of knowledge is making my explaination unclear.
I am working in Revit Architecture LT 2013
Sat, Sep 29, 2012 at 4:45:01 AM | Nested Revit Window vertical Alignment
4 Stars: 205 Votes
Hope this HELP: http://www.revitcity.com/tutorials/arrays_and_nested/
Sun, Sep 30, 2012 at 9:56:56 AM | Nested Revit Window vertical Alignment
mcapri92
I realized the issue had to be resolved with adding a height above reference plane for the nested family which could then be linked to the default sill height.
Nested window family not appearing in window legend
Wed, Jun 3, 2009 at 4:13:11 PM
Schedule Nested Window Family
Tue, Feb 10, 2009 at 4:14:34 PM
Nested family always vertical?
Mon, May 16, 2011 at 2:55:02 PM
nested families do not cut
Thu, Jan 14, 2010 at 11:44:55 AM
room tag alignment
Wed, Sep 24, 2008 at 9:38:04 PM
Page generation time: 1.5167
