Forums >> Revit Building >> Technical Support >> keynotes by sheet text randomly disappearing
Fri, Sep 28, 2012 at 10:10:51 AM | keynotes by sheet text randomly disappearing
db
I have some keynotes acting funny on a plan.  They are numbered "by sheet".   The text in the bubble is disappearing with no obvious rhyme or reason.   They are still asociated with the correnct keynote list. (the correct key value # still shows in the keynote's properties)  The annotation crops don't fix it when turned off.  Has anyone experienced this?   thanks.
Fri, Sep 28, 2012 at 12:28:48 PM | keynotes by sheet text randomly disappearing
Are they keynote by materials or element or user?
Fri, Sep 28, 2012 at 2:34:36 PM | keynotes by sheet text randomly disappearing
db
they are by user
Fri, Sep 28, 2012 at 3:11:32 PM | keynotes by sheet text randomly disappearing
Do you have a keynote list on the sheet then?
Fri, Sep 28, 2012 at 3:28:20 PM | keynotes by sheet text randomly disappearing
db
yes,   the keynote list on the sheet is fine.   All of the notes still appear in the list, even if the keynote on the drawing goes blank.   I thought it might have something to do with the annotation crops but it seems like that would also hide the keynote symbol.   The symbol remains and is still associated with the keynote list, but no #.
Mon, Oct 1, 2012 at 9:21:48 AM | keynotes by sheet text randomly disappearing
db
maybe i'm the only one whos had this...  thanks for the help.
Mon, Oct 1, 2012 at 9:44:13 AM | keynotes by sheet text randomly disappearing
This is not a dependent view with different crops is it?  I have seen problems where the element is not in the crop area.
Otherwise - sorry.....
Mon, Oct 1, 2012 at 10:15:52 AM | keynotes by sheet text randomly disappearing
db
i have a overall view with dependant views off of it using scope boxes for the different areas.
Mon, Oct 1, 2012 at 10:44:11 AM | keynotes by sheet text randomly disappearing
Ah.... This may be your problem then.  Are these problematic keynotes along the scope boxes?  You might try moving the user keynote so that it is within your scope box.
We usually have to have one on both sides of the crop because of this problem.
Mon, Oct 1, 2012 at 10:58:15 AM | keynotes by sheet text randomly disappearing
db
thanks...  I see.   That may very well be it.  But some are not too close to the box, and it's just the # that doesn't show,,, the key still does...
Anyway,  i'll play with that in mind and see what happens.  thanks again.
Keynotes - Ledgend management
Mon, May 11, 2009 at 7:01:29 AM
View References in Text and Keynotes
Fri, May 22, 2015 at 1:05:20 PM
Revit Keynotes missing text
Thu, Mar 5, 2015 at 1:11:31 PM
Keynote Legend Not Showing Keynote Text
Fri, Sep 6, 2013 at 11:40:59 AM
12
KeyNotes
Wed, Aug 7, 2013 at 9:11:47 AM
Page generation time: 0.4230
