13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Revision cloud closes revit
I have a user that is trying ot create a revision cloud in 2013 around a large area. When he closes the sketch mode for the revision cloud revit closes. No options to create a recovery file or submit to Autodesk. When he makes a smaller revision cloud everything is fine. Any ideas?
Not a clue .... But why are you doing revisions clouds in the view? We only do them on the sheets, much easier to do and coordinate.
I just found the answer on Autodesk forum. 2013 has a known defect that if there are more than 100 undo points in sketch mode it will crash when you close the sketch mode. The work around, until Autodesk hopefully fixes this, is to draw less than 100 points. Close teh sketch mode. Tehn edit it again and add more points.
Have you downloaded the Revit Update Release 1 yet? I was having a problem with toposurfaces doing something similar, I could only create so many points otherwise when I tried to complete revit just crashed. After I downloaded the update it seemed like I had no problems any more. Maybe this would help you also.
Hiding a Revision in the Revision Schedule |
Thu, Nov 21, 2013 at 3:04:51 PM
Issue/revision line item showing up with revision cloud |
Tue, Aug 14, 2012 at 9:01:03 AM
Revision Cloud graphics |
Mon, Aug 24, 2020 at 7:00:24 AM
Revision cloud parameters |
Mon, Feb 25, 2008 at 7:53:53 PM
Revision cloud |
Tue, Sep 2, 2008 at 9:35:26 AM
