29 Users Online (27 Members):
Forums >> Revit Building >> Technical Support >> ellipses and railings, curtain systems and walls
i've cut a partial elliptical hole in a mezzanine floor for a performance hall. it kicks some major....
but i can't figure out how to put a rail (curtain system or wall) on the partial ellipse?
Ah yes....ellipses in Revit can cause problems. Hey until i think 7.0 they weren't even an option though!
I don't think the railing tool will allow you to sketch or pick an ellipse. You may have to use an arc or series of arcs to appoximate an ellipse. I'm not good at the math behind an ellipse but I think someone over on AUGI did some tutorials on arcs that approximate ellipses.
As for the walls and curtain walls, you may need to create a mass in the shape of the ellipse and use the wall by face and curtain wall by face tool.
Others may have more or better advice as I live in a big box world without ellipses.
Tom
try to draw a drafting line (use the pick tool) than during the sketch pick the lines... it should work, let us know if not
solid walls transparent to curtain walls and railings in back.. |
Mon, Oct 29, 2012 at 7:34:26 AM
Curtain System from Mass - Mullion Joins |
Fri, Dec 11, 2015 at 7:27:44 PM
Creating Curtain Wall Schedules |
Thu, Sep 14, 2017 at 11:59:47 AM
Scheduling Walls and Railings together into one schedul |
Wed, Aug 22, 2012 at 7:17:37 AM
Angled Curtain Walls - fillets and nested |
Thu, Apr 23, 2009 at 5:42:47 PM
