Forums >> Revit Building >> Technical Support >> Creating irregular patterns with divide surface
Thu, Sep 27, 2012 at 1:34:19 PM | Creating irregular patterns with divide surface
10samcarl
When you use the divide surface tool, Revit automatically creates identical, equally sized divisions on a face.
I want to know if there is some way to individually manipulate these gridlines or divisions to create irregular patterns or
panels of different sizes. I'm using the divide surface tool to make curtain panel systems on the outside of a building,
and I dont want the panels to be arranged in a regular grid.
thanks
Fri, Sep 28, 2012 at 10:00:35 AM | Creating irregular patterns with divide surface
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
Most of the properties of the object that is repeated are "consumed" by the repetition, meaning that somehow its parameters become unavailable for further use after the object has been repeated. The only control possible, so far, is to use adaptive points in the original object that is going to be repeated, and relate the location of that adpative point to one of the dimensions of the object. Then, after the object is repeated, that distance can used to create variations in the object. There is a sample of this method in Zach Kron's blog.
Planta1 Revit Online Consulting | info@planta1.com
Divide Surface of conceptuall mass by level?
Wed, Jan 13, 2010 at 5:23:14 AM
Created forms and divide surface tools
Wed, Jan 1, 2014 at 4:34:46 AM
how to make an irregular slope surface
Fri, Apr 1, 2011 at 10:12:27 PM
View dependent material surface patterns
Wed, Apr 22, 2015 at 1:57:55 PM
Surface Patterns in Perspective
Fri, Jan 27, 2012 at 7:04:34 AM
Page generation time: 2.4802
