Forums >> General Discussion >> Revit Project Management >> Issue creating mass floor area schedule (mix of families & 'model in place' mass
Thu, Sep 27, 2012 at 3:56:42 AM | Issue creating mass floor area schedule (mix of families & 'model in place' mass
calle05
Hi. I'm created a mass floor schedule (for calc of floor areas). Background: I have created differenent tpes of family and 'model in place' masses (to represent building volumes - used mass floors). So there are several different family names. However, when i create a 'model in place' mass, I cannot name it the same thing as other families that I eventually want to group together in a mass floor schedule. For example, I created a family called 'office' so i had to name a 'model in place' mass 'office 2'. I want both to be counted as simply 'office' area. This is a problem in the mass floor area schedule as they are obviously two different items in the schedule at the moment...Is there a good way of somehow grouping families and 'model in place' masses? Can I create a new parameter in 'available fields' in schedule properties? Really need to work around this problem, any suggestions much appreciated.Thanks
Thu, Sep 27, 2012 at 7:05:36 AM | Issue creating mass floor area schedule (mix of families & 'model in place' mass
Add a project, shared parameter to both types and use that as a sort/filter.
Creating a schedule for floor areas - families and model in-place mass
Mon, Sep 17, 2012 at 3:00:21 PM
'forms' not available in 'in place mass' or components.please help
Fri, Aug 30, 2013 at 3:20:58 AM
Attatching an image to a 'Model in Place' mass
Fri, Apr 27, 2012 at 9:36:34 AM
Mass? instead of creating "floor area faces" can on create "section area faces"
Tue, Apr 25, 2006 at 1:56:40 PM
extruded generic model and mass floors (2012)
Fri, Sep 21, 2018 at 3:36:03 AM
Page generation time: 4.0501
