Forums >> Revit Building >> Technical Support >> Thermostats In REVIT MEP 2012
Tue, Sep 25, 2012 at 1:48:08 PM | Thermostats In REVIT MEP 2012
ah1425
Is it possible to link families together, i.e. thermostat to unit heater.
Currently as a company standard, we lable the thermostat w/ text corresponding to the equipment it controls. The way we are doing it now is we have mechanical equipment family created for the t-stat and tag it. However when this is done you get an error that says something to the effect of "Elements have duplicate mark values". Not a huge deal but is annoying.
Anyway, what i would like to do is when a piece of equipment is placed i would like to "link" the thermostat to it in such a way that the mark value will carry through. this would also solve a problem of changing equipment names but forgetting to change the thermostat tag.
This is probably not possibe but just thought i would check if anyone has done anything similar.
Revit MEP 2012 View Port Error with Linked views
Tue, Sep 4, 2012 at 11:50:45 AM
TRIMMING PIPES - MEP 2012
Fri, Sep 21, 2012 at 9:06:37 AM
PIPE ELBOWS MISMATCH in F-REVIT 2012 MEP
Mon, Apr 15, 2013 at 2:52:28 PM
Hide insulation in MEP 2012
Wed, Sep 5, 2012 at 3:39:14 AM
Revit MEP 2012-View Range
Fri, Apr 12, 2013 at 7:22:48 AM
Page generation time: 3.6334
