Forums >> Revit Building >> Technical Support >> Pleated blind.
Tue, Sep 25, 2012 at 8:29:01 AM | Pleated blind.
JRPcad
Hey guys,
I'm trying to create a family for a pleated blind in a window for a client, The family seems okay but he has asked for a close up detail of how the pleat fits into fitting for it, Now I've fudged it a bit and have made the blind a 1mm thick extrusion, obviously for the close up this shows too thick as the actual material is no more than .3mm thick, I was hoping to just amend the extrusion for the pleat to .3mm thick but i got the typical "line too short" error!
Does anyone know a work around for this or maybe just a way of creating a simple flat surface with no actual thickness would also suffice. any help will be appreciated.
Thanks
For Architectural Services visit www.jrpcad.co.uk
Tue, Sep 25, 2012 at 8:32:53 AM | Pleated blind.
JRPcad
Lol never mind,
I just had a bit of an epithany as i clicked submit, i drew the line of the length i wanted then attached a very shallow arch to each of it's ends, i've managed to get it down to about .1mm thick, could have probably gone less, and i don't think it will be noticable in the slightest Winking
array of nested objects
Sun, May 27, 2007 at 7:16:14 PM
rooms??
Tue, Oct 29, 2013 at 10:47:21 AM
Family Array
Thu, Dec 31, 2009 at 3:46:22 PM
Array Family
Thu, Dec 31, 2009 at 3:01:57 PM
binding revit links
Sun, Nov 18, 2012 at 12:04:08 PM
Page generation time: 0.0083
