Forums >> Revit Building >> Technical Support >> Corner guards to snap to corner of wall
Mon, Sep 24, 2012 at 1:09:07 PM | Corner guards to snap to corner of wall
jeanietam1
I've downloaded a couple of corner guard families but it seems like the piece only snaps one leg of it to the face of the wall, and not the corner.  What ends up happening is that, instead of rotating to accommodate the corner configuration, the corner guard now shows up embedded into the wall.  CryingPlease see attached jpg)  Is there a way to create an "axis hosted" or "line hosted" family, so that it will snap to the corner of the wall?  Thanks in advance!
Mon, Sep 24, 2012 at 1:11:29 PM | Corner guards to snap to corner of wall
That corner guard family needs a flipper added then jut dag it over to the corner.
Mon, Sep 24, 2012 at 1:51:43 PM | Corner guards to snap to corner of wall
TKennedy
4 Stars: 8 Votes
You can do what WWHub said, and/or change the insertion point ref planes so the are where you want them to be.
Mon, Sep 24, 2012 at 2:00:58 PM | Corner guards to snap to corner of wall
TKennedy,
Are you suggesting ref planes at the corner of every wall... or 2 ref planes at ea corner?  .... really?
Mon, Sep 24, 2012 at 3:05:38 PM | Corner guards to snap to corner of wall
jeanietam1
Hi WWHub and TKennedy!  Thanks for your suggestions.
I've changed the insertion point to where I want it to be, so now the origin is in the correct spot when I insert it, but how do I add a "flipper" or something that will rotate it into the correct orientation?
Jeanie
Mon, Sep 24, 2012 at 3:07:00 PM | Corner guards to snap to corner of wall
Edit the family to insert the flipper.
Thu, Dec 5, 2013 at 2:07:57 PM | Corner guards to snap to corner of wall
jwellsbim
I have a corner guard family that might work for you
Jason Wells
"The People Who Are Crazy Enough To Think They Can Change The World Are The Ones Who Do" Steve Job
Thu, Mar 13, 2014 at 2:28:40 PM | Corner guards to snap to corner of wall
jeanietam1
Hi,
Thanks for the family.  Would you mind saving it to R2013?  It seems like it was created by a newer version.  Thanks!
Jeanie
Tue, May 13, 2014 at 12:18:44 PM | Corner guards to snap to corner of wall
jwellsbim
You can not save Revit back to 2013 i'd have to recreate it
Jason Wells
Detail Line Snap Override
Tue, Oct 11, 2011 at 7:47:44 AM
Corner windows with variable angle
Tue, Dec 27, 2016 at 4:47:10 PM
Plumbing fixture and snapping to corner
Fri, Apr 4, 2008 at 2:46:40 AM
corner windows
Tue, Jun 3, 2008 at 10:56:06 AM
wall sweep inside corner
Mon, Dec 18, 2006 at 9:07:04 AM
Page generation time: 1.1975
