Forums >> General Discussion >> Revit Project Management >> Annotation Crop boundary is not visible
Mon, Sep 24, 2012 at 1:00:47 PM | Annotation Crop boundary is not visible
jeanietam1
I've checked off "Crop View", "Crop Region Visible" and "Annotation Crop" in all my views.  However, there a a stubborn few that would not show the "Annotation Crop" boundary, while the others shows both crop and annotation boundaries perfectly fine.  Any idea what I'm doing wrong?
I'm using Revit Architecture 2012.  Thanks!
Mon, Sep 24, 2012 at 1:10:15 PM | Annotation Crop boundary is not visible
Are you talking about the vrop boundry window in the view or in the plan call-out?  They are different.
If the crop boundry doesn't show in a plan, click on the elevation view and change the clipping plane from no-clip.
Mon, Sep 24, 2012 at 2:03:07 PM | Annotation Crop boundary is not visible
jeanietam1
Hi WWHub,
Thanks for your suggestion.  It's the annotation crop boundary in a view that I'm having trouble with showing.  I've checked the clipping plane as you've suggested and it's already set to "no clip".  Any other ideas?
Jeanie
Mon, Sep 24, 2012 at 3:05:06 PM | Annotation Crop boundary is not visible
In my post I said to "...change it from no-clip" and that was in respect to how it shows in the plan.
Sorry - I read your post again.  You are talking about the annotation crop boundry?  It has to be on and it will not show until you roll-over the crop boundry in the activated view.
Mon, Sep 24, 2012 at 3:16:13 PM | Annotation Crop boundary is not visible
jeanietam1
Thanks WWHub!
Room Tags and Crop Regions
Wed, Sep 28, 2005 at 10:41:25 AM
Crop Regions Disappear When I Assign a View Template
Sun, Apr 22, 2018 at 11:04:20 PM
Crop boundary won't export to autocad
Mon, Jun 16, 2008 at 12:49:03 PM
Silly Grid Crop Question
Mon, Mar 14, 2016 at 2:54:20 PM
crop region
Fri, Feb 25, 2011 at 1:21:49 PM
Page generation time: 0.1679
