Forums >> Revit Structure >> Technical Support >> Vertical bracing in plan question
Mon, Sep 24, 2012 at 7:38:16 AM | Vertical bracing in plan question
cundall
If you’re detail level is set to Course, the vertical bracing showing in a plan view is shown offset from centre of columns (or grid) in a dashed line
My question: Is there a way to make the vertical bracing (Course detail level) in plan show up centred on column instead of shown offset ??
I hope this makes sense
Cheers
Edited on: Mon, Sep 24, 2012 at 7:39:55 AM
Mon, Sep 24, 2012 at 11:01:24 AM | Vertical bracing in plan question
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
What is the bracing placed as? Is it a revit family? componet?  Eitherway you will most likely need to go into the family and see what symbolic lines are shown that is making the offset show at different detail levels and change the object style in the family.
Mon, Sep 24, 2012 at 2:13:10 PM | Vertical bracing in plan question
kathey1
yes i need help with this too, i use the brace tool to model my vertical bracing. how do you modify the symbolic lines within a family ???
Edited on: Mon, Sep 24, 2012 at 2:17:04 PM
Tue, Sep 25, 2012 at 2:54:28 AM | Vertical bracing in plan question
cundall
ive sorted it, if your go into manage tab, structural settings, under brace symbols> parallel line offset> set it to 0 ! easy !
Wed, Sep 26, 2012 at 1:01:35 AM | Vertical bracing in plan question
IoanIancu
2.5 Stars: 2 Votes
The out-of-box families do not work for most bracing, unless the bracing member is symmetrical. Tubes, pipes and WF work OK. also the Double angle family works. But single angles and WT's do not work. But single angles and WT's can work if the family is revised for bracing, so that the bracing members center reference plane works with the analytical layout of the bracing.
scrapbooking
Vertical bracing symbolic line ???
Tue, Jun 4, 2013 at 7:33:50 AM
Vertical bracing line
Sun, Jun 2, 2013 at 2:17:03 AM
Revit 2014 Vertical Bracing Problems
Thu, Feb 20, 2014 at 10:26:00 AM
Vertical and horizontal bracing connections
Mon, Jun 24, 2013 at 7:18:38 AM
vertical bracing problem / bug
Wed, Jan 18, 2012 at 3:13:12 AM
Page generation time: 4.0996
