Forums >> Revit Building >> Technical Support >> Revit 2013 family
Fri, Sep 21, 2012 at 2:17:00 AM | Revit 2013 family
Nicolai
I want to make a family roombouding. Is that possible???
Fri, Sep 21, 2012 at 8:44:22 AM | Revit 2013 family
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
There is not a way to make a family room bounding.  A workaround I found in another thread
"A workaround is to create a seperate Revit project, load your family, add the room sep lines, group everything and save out the group as a new Revit project. Then when you need to use the family,in a new project you load and place the group which contains the family and the room sep lines."
Revit 2013 Deleting Hosted Families
Mon, Feb 11, 2013 at 12:05:45 PM
Need a help with REVIT 2013 Templates and Family insttallation files
Sun, Aug 4, 2019 at 8:38:10 AM
Ref Level Missing in Family Editor 2013
Thu, Aug 22, 2013 at 5:05:39 PM
REVIT 2013 Materials Library Video Tutorial
Tue, May 28, 2013 at 5:12:56 AM
13
Problem with Revit 2013 Not Responding
Thu, Oct 10, 2013 at 12:25:28 PM
11
Page generation time: 1.7670
