Forums >> Revit Building >> Technical Support >> global material search and replace
Wed, Sep 19, 2012 at 11:13:59 AM | global material search and replace
vrmoreno3
Revit 2013 - I am looking for a way to globally select a material and change it to something else.
Wed, Sep 19, 2012 at 11:34:54 AM | global material search and replace
If you change the material in the material library, it will change that everywhere.
Wed, Sep 19, 2012 at 11:48:45 AM | global material search and replace
vrmoreno3
Yeah I kinda figured that one out after thinking. I have two materials, one is masonry - brown brick and masonry - red brick. I wanted to globally change the "brown" to "red" material. Changing the material pattern in the material might be the easist way.
Wed, Jul 19, 2017 at 4:20:02 PM | global material search and replace
PolynineStudio
You also have the ability to merge materials using our plugin.
For example, if your project uses red brick and brown brick, and you would like to use the red brick globally you coud replace brown brick material with the red brick. The Revit built-in solution is to change the brown brick to look like the red brick; in this scenario you still have two individual materials that you have to maintain.
https://apps.autodesk.com/RVT/en/Detail/Index?id=6565035931500761028&appLang=en&os=Win64
www.polyninestudio.com
Material search
Thu, Jun 18, 2009 at 8:11:49 AM
global swap of filled regions?
Sat, Jul 2, 2005 at 10:34:09 PM
Revit Structure 2008 and NVIDA card settings?
Thu, May 1, 2008 at 4:13:11 AM
Find & Replace
Mon, Feb 22, 2010 at 9:27:05 AM
14
Cannot replace panels in a Curtain Wall, then copy
Mon, Apr 12, 2010 at 1:37:20 PM
Page generation time: 1.2908
