15 Users Online (13 Members):
Forums >> Revit Structure >> Tips & Tricks >> beams
hi, we are working on a school project and we need to do the structural plans like on the attached images, i will like to know which beams are in the example.
the problem is that we have the class in spanish and we are using revit in english, so beams names are kinda different and really dont know if we can detail it that much
i really appreciate since its a very important project
thanks in advance
try this website: http://www.spanishdict.com/translation. They use different sources for translation and give examples in both English and Spanish. Buena suerte.
jlights |
thanks, i know english very well, the issue will be that here beams are not called the same except for some joist, even if we took spanish away is it possible to have the type of beams with its details as on the pictureS?
thanks
try using K-Series Bar Joist-Rod Web and K-Series Bar Joist-Angle Web, these come in your library. espero y te sirban
joining two beams |
Fri, Jul 6, 2007 at 12:03:10 PM
making beams dotted and upstands |
Tue, Jun 3, 2008 at 3:50:24 AM
Beams that are copied are invisible, while beams placed can be seen?? |
Sat, Jan 20, 2007 at 9:53:43 AM
RVT2015 - Insert steel beams over doorway |
Tue, Apr 25, 2017 at 9:06:47 PM
Battered ends of L-Beams |
Thu, May 9, 2013 at 12:32:50 PM
