Forums >> Revit Building >> Technical Support >> Arch 2012 Conditional Formatting
Tue, Sep 18, 2012 at 10:54:46 AM | Arch 2012 Conditional Formatting
DTCesarz
DTCesarz Avatar
5 Stars: 4 Votes
I am working on a door schedule and am trying to create a conditional format attempting to format double doors as "2@ 3'-0" instead of 6'.  My formatting would also include uneven doors (i.e. 2'/3').  I've tried working with both length and text types to try to achieve this and feel I am almost there if I use the length but need to be able to include a prefix to say our "width" or "panel type 1 or 2" parameter.  It would read something like if(Width = 6', "2 @" Width/2, if(Width...  the "2 @" would be my prefix but can only get text to work in the text category and length to length. Maybe this is a wishlist item???
Tue, Sep 18, 2012 at 11:08:38 AM | Arch 2012 Conditional Formatting
There are no text formula's in Revit other than =, so no concatenations.
We have not really solved this unequal pair problems in schedules and I don't see any good solution yet.  We do have a "Pair" column and a calculated width column using the pair and door with parameter.  Then we end up using a paper space work around.  << UGLY.
conditional formatting yes no parameters
Tue, Oct 28, 2008 at 9:58:54 AM
can you hide zeroes in schedules?
Tue, Feb 14, 2012 at 1:26:55 PM
Conditional statement
Thu, Jun 27, 2013 at 9:58:47 AM
Schedules
Tue, Nov 11, 2014 at 9:05:13 AM
Grid Bubble formatting between projects
Sun, Oct 26, 2014 at 8:33:04 AM
Page generation time: 0.1826
