Forums >> Revit Building >> Technical Support >> Request for help in cut and fill tool
Tue, Sep 18, 2012 at 2:14:26 AM | Request for help in cut and fill tool
kitang007
5 Stars: 2 Votes
Good afternoon everyoneI have been using Revit 2011 architecture. I had created a topography using 'create from instance' and then I 'created a new toposurface exactly like the existing one' using the graded region. But the problem was on showing the new phase my properties toolbar was not showing the net cut and fill data. I tried referring many videos but could not solve the problem. Since I have a college submission on my head therefore i had started with my work. So i have few building pads, modified contours, one subregion in my new topography. My doubt is if it is possible to get the cut and fill data now. ? If anyone has understood me i can well mail the file. Thank You
Tue, Sep 25, 2012 at 3:34:46 PM | Request for help in cut and fill tool
stealthnyc
4.5 Stars: 2 Votes
Did you create a topography schedule?  You can add parameters for cut/fill/net cut/fill there
Wed, Sep 26, 2012 at 12:01:41 AM | Request for help in cut and fill tool
kitang007
5 Stars: 2 Votes
yes  I created a schedule too. Every parameter is showing value 0 (zero)
Wed, Sep 26, 2012 at 6:19:24 AM | Request for help in cut and fill tool
stealthnyc
4.5 Stars: 2 Votes
When you made the first topography from the cad import did you set it to the "existing" phase before you used the graded region tool?
Wed, Sep 26, 2012 at 9:18:03 AM | Request for help in cut and fill tool
kitang007
5 Stars: 2 Votes
WELL I AM NOT SURE ABOUT THAT.. I DONT THINK SO. if this is the reason for revit not showing cut and fill, then is there a way in which the cut and fill volumes can be known.. i had started working with the new construction site and have altered it to the extent that the owrk cannot be started again. please let me know.Thank You
Wed, Sep 26, 2012 at 9:40:50 AM | Request for help in cut and fill tool
stealthnyc
4.5 Stars: 2 Votes
I did a test and it still showed the cut and fill even though the first topography was set to New Construction.  Check your schedule and make sure the phase is set to New Construction.  I'm not sure what else it would be.  Unless you can post the file on here.
Wed, Sep 26, 2012 at 9:57:53 AM | Request for help in cut and fill tool
kitang007
5 Stars: 2 Votes
can you please give me your email id? The file size limit won't let me mail the file.
Wed, Sep 26, 2012 at 10:36:38 AM | Request for help in cut and fill tool
stealthnyc
4.5 Stars: 2 Votes
Can you delete everything except the topography, and do a purge?
Wed, Sep 26, 2012 at 11:58:44 AM | Request for help in cut and fill tool
kitang007
5 Stars: 2 Votes
yes sir Thank You so much Sir. I guess the purge unused has worked . Thank You so much Smile Smile
Wed, Sep 26, 2012 at 12:12:17 PM | Request for help in cut and fill tool
stealthnyc
4.5 Stars: 2 Votes
I don't see the file attached.
Revit Cut and Fill
Thu, Jan 13, 2011 at 5:02:33 PM
Siteworks Cut & Fill
Wed, Jun 1, 2011 at 5:12:56 AM
Topography Cut/Fill Schedule
Thu, Nov 16, 2006 at 11:15:51 AM
Creating a Cut + Fill
Tue, Mar 31, 2015 at 10:58:46 PM
Cut and Fill
Fri, Sep 16, 2005 at 8:16:14 PM
Page generation time: 0.7782
