Forums >> Revit Building >> Technical Support >> Rendering problems
Mon, Sep 17, 2012 at 8:57:09 PM | Rendering problems
BINET
I ma using Revit 2013.
I am trying to create a high resolution image of a house with landscaping to use on a brochure.
I set render dialog box to print 600dpi. My computer would not do anything. I reduced the dpi to 300 and it rendered the image but would not allow me to export it or save it to project. I then rendered the image at 150 dpi and it allowed me to save and export it. !!!!!
What is going on?
In a previous version of Revit i was able to render at 600dpi no problems.
Tue, Sep 18, 2012 at 3:58:00 AM | Rendering problems
4 Stars: 205 Votes
Hmmm.. memory issues, what's specs. of your machine? I never had this problem....
Tue, Sep 18, 2012 at 8:48:18 AM | Rendering problems
AbsoluteBIM
AbsoluteBIM Avatar
4 Stars: 4 Votes
I have this same issue with hi res renderings and it's my machines that is getting old. I have to keep an eye on the "uncompressed image size" and make sure its stays below 50 MB. Sorry to say it, but when you upgrade software, you'll eventually need to upgrade your machine.
Tue, Sep 18, 2012 at 12:20:01 PM | Rendering problems
rbcameron2
rbcameron2 Avatar
4 Stars: 25 Votes
Maybe memory related.  See link below (although it isn't very informative)
http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/1468-Document1468/2034-Renderin2034/2149-Troubles2149/2152-Not_Enou2152
FYI, in my opinion, 1333Mhz - 16Gb RAM is the new "normal" for a Revit computer.
You might be able to reallocate your paging file in Windows and set it to something higher.
RB Cameron
3D Medical Equipment
Download Revit Healthcare Models Now
Download Other Revit + 3dsMax Models Here
Problems with Best quality nighttime rendering.
Tue, Dec 4, 2012 at 8:32:13 PM
Rendering Problems
Wed, Jun 18, 2008 at 6:48:29 AM
12
Rendering problems
Tue, Sep 12, 2017 at 9:55:21 AM
help with rendering!
Wed, Aug 10, 2016 at 10:47:17 PM
Can a 63mb Revit File Size cause problems during rendering?
Mon, Nov 2, 2015 at 6:29:45 AM
Page generation time: 1.1280
