Forums >> Revit Building >> Technical Support >> Room Tags - Tagging all Rooms at Once??
Mon, Sep 17, 2012 at 10:09:56 AM | Room Tags - Tagging all Rooms at Once??
Agile3100
Hi I am currently using Revit MEP 2012 and am working on an arena project. I would like to know if there is a way to tag all the rooms in the project at once rather than one at a time, or if i do have to tag them one at a time can i make them show up in other views? Seems like it should be a simple thing but I'm just not seeing how to do this. Any suggestions are appreciated, Thanks.
Mon, Sep 17, 2012 at 10:21:28 AM | Room Tags - Tagging all Rooms at Once??
Rooms are 3D so once the properties are set, you don't have to do that for other views.  Room tags though are 2D so they have to be placed in each view.
Under the room and area  / tag pull down - is tag not all and you can pick rooms.  BTW, once you have a view all tagged and the tags where you want them, you can window the view, filter for room tags and copy/paste them to any viw, no matgter what scale it is.
Mon, Sep 17, 2012 at 11:23:17 AM | Agile3100
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting Agile3100 from 2012-09-17 10:09:56
Most annotations are view specific, they only show in the view that they are placed-in.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Mon, Sep 17, 2012 at 11:40:17 AM | Room Tags - Tagging all Rooms at Once??
Agile3100
I cant "tag all" but i didn't know about being able to copy and paste them vrom view to view, Thanks!
Want to see Room Tags but not Rooms
Wed, Oct 5, 2016 at 11:37:51 PM
Room Tags - Tagging Multiple Rooms as One
Tue, Feb 19, 2008 at 1:25:28 PM
tagging rooms in linked files
Mon, Jan 13, 2014 at 3:26:05 PM
Select room tags; copy rooms to new phase
Thu, Jun 29, 2006 at 7:19:48 AM
DELETING ROOMS WITHOUT VISIBLE TAGS
Thu, May 4, 2006 at 6:59:11 AM
Page generation time: 0.3650
