Forums >> Revit Building >> Technical Support >> Importing DWG with clipped blocks
Sat, Sep 15, 2012 at 11:50:38 AM | Importing DWG with clipped blocks
HP11
I am noticing that when CAD files are imported that any clips to blocks of xrefs are not maintained in the Revit model.  Has anyone noticed this before and is there a way to control this without first exploding or binding that DWG before importing?  Thanks!
Mon, Sep 17, 2012 at 7:38:18 AM | Importing DWG with clipped blocks
Are the xref's pathed correctly and in the correct folder?
Mon, Sep 17, 2012 at 12:00:44 PM | Importing DWG with clipped blocks
HP11
All paths within the CAD file are correctly linked.  Does Revit require a particular set up of xreferenced or block files?
*Using Revit 2012
ACAD Import Problems (With Blocks)
Mon, Jan 12, 2009 at 5:26:46 AM
AutoCAD DWG Blocks
Sun, May 9, 2010 at 10:43:13 AM
Exporting views with DWG bocks to dwg.
Sun, May 21, 2006 at 8:36:59 PM
not to see imported dwg on every level (after importing dwg)
Sun, Nov 26, 2006 at 11:13:58 PM
dwg 3D blocks
Wed, Dec 3, 2003 at 6:37:53 PM
Page generation time: 1.7855
