Forums >> Revit Structure >> Tips & Tricks >> Importing Survey Points (As-Built Points) into RST
Sat, Sep 15, 2012 at 11:16:24 AM | Importing Survey Points (As-Built Points) into RST
krunung
This problem has plagued me for some time now and I wish there was an easy way to do it but, at least to this point, it has eluded me. I've been charged with the task of incorporating the as-built points that our surveyor recorded in the field into our building model. He basically recorded the points into his survey equipment and exported a .txt file, a .csv file, and a .dxf file of the points.
I looked into the point cloud option but the survey equipment that we have doesn't export to the point cloud format and I don't have any experience with them. I know that they are mainly used with special equipment that we don't have and, really, don't need. The .dxf file obviously opens fine in AutoCAD but they can't be compared with the Revit model. If I insert the .dxf file into Revit, the inserted drawings just shows the points for each but I can't dimension to them, I can't manipulate them. If I explode it, the points go away and I'm in the same boat as before.
I'm hoping that someone out there has done this and knows an easy way to get these points in and be able to dimension to/manipulate them. Please help me... :-( Very frustrating. So close but very far. Open to any and all suggestions.
Thanks,
Kris Runung
Project Manager/Engineer
McClone Construction Co
Wheat Ridge, CO 80033
Create topography from instance not picking up points
Wed, Jan 30, 2013 at 9:51:10 AM
coordinates from survey into revit [ 1 2 ]
Sun, Jul 21, 2013 at 9:51:57 AM
27
Possible to place contour lines to toposurface instead of points?
Fri, Jun 1, 2018 at 2:57:52 PM
Topography points Crash in Revit 2013
Wed, Oct 31, 2012 at 4:34:47 AM
Topography won't generate off points
Fri, Oct 27, 2017 at 5:09:56 AM
Page generation time: 0.3203
