Forums >> Revit Systems >> Technical Support >> Can piping be radiused around a duct?
Fri, Sep 14, 2012 at 11:22:16 AM | Can piping be radiused around a duct?
rkeytek
Hey Everyone,
I am trying to show 3/8 tubing wrapped around a 8-0 dia. duct for I&C design but I do not see there is a feature for that capability.
My short fix is to create a sweep profile but not able to create connections perpendicular to the tubing.
All suggestions are welcomed.
Screen shot provided.
Fri, Sep 14, 2012 at 2:30:36 PM | Can piping be radiused around a duct?
stealthnyc
4.5 Stars: 2 Votes
You probably have to create a special pipe fitting for this that is a loop.  You could add a parameter to make the loop to a certain diameter.  Then add your pipe connectors into the fitting.
Thu, Oct 4, 2012 at 10:05:09 AM | Can piping be radiused around a duct?
Gyvven
5 Stars: 2 Votes
Could be a job for Adaptive Components? I've been looking for something that I could try them out on. Most things in MEP don't lend themselves well to adaptive components but this might do nicely.
Duct Fitting Issue
Tue, Apr 1, 2014 at 1:16:35 PM
Rectangular Flanged Square Duct Fitting 45 Degree
Mon, Jun 17, 2013 at 4:46:32 AM
Duct won't tap to oval duct.
Tue, Aug 22, 2017 at 12:38:49 AM
Eccentric Duct Fittings?
Thu, Dec 15, 2011 at 10:58:31 AM
Autocad MEP duct work question
Thu, Feb 17, 2011 at 11:12:01 AM
Page generation time: 2.2403
