9 Users Online (8 Members):
Forums >> Revit Systems >> Technical Support >> Auto-apply changes
8 Posts No Rating |
Is there a way to stop Revit automatically applying changes made in the properties pane? It's very frustrating when you're halfway through changing something and it applies the changes before you're finished.
Thanks
Keep your curser inside the property dialog box, nothing will get updated until you pull your curser into the work area. You can also use the TAB key to move down the list in the properties instead of moving the curser to avoid accidentally moving into the work area.
8 Posts No Rating |
Ah, very subtle, thank you very much.
Auto Cad 3D and Revit 2009 |
Thu, Aug 20, 2009 at 7:18:39 PM
Importing Revit Layers into Auto CADD |
Mon, Nov 19, 2007 at 8:09:11 PM
Auto Tag-Wall Tags |
Tue, Apr 11, 2006 at 1:33:16 AM
Auto dimension And curtain Walls |
Tue, Apr 17, 2012 at 3:59:50 PM
is there an "auto save" |
Tue, Mar 14, 2006 at 6:47:03 PM
