18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Splitting Revsiion schedule into 2 in 2013
2 Posts No Rating |
I have looked almost everywhere and am wondering how can you break a revision schedule into 2 parts (columns) so it can fit into the title block when it gets too many items in it? Otherwise using revits built in revision function, how would you make this work? Any suggestion would be appreciated.
209 Posts No Rating |
you will notice there is a split tab on the sides of the schedule on the sheet once you split it drag the second half onto the sheet. .
2 Posts No Rating |
not with revision schedules-they dont have the split like other schedules
oh your using the schedule within the title block thats right. Then you cannot split it and duplication will still populate the same info. If you want the information to only appear once then your stuck with one.
Schedules - Splitting Same Schedule in different ways? |
Thu, Jan 14, 2021 at 12:29:21 PM
Splitting Drawing List and Door Schedule... |
Thu, Jun 10, 2010 at 3:08:27 PM
Splitting imported text blocks |
Thu, Feb 16, 2006 at 4:18:14 PM
Splitting a wall with a Reveal |
Fri, Feb 19, 2010 at 11:25:44 AM
Revit 2013: Window to Wall Ratio Schedule |
Tue, Jul 15, 2014 at 8:47:20 PM
