Forums >> Revit Building >> Technical Support >> can revit make a sequence of renderings ?
Thu, Sep 13, 2012 at 12:41:50 PM | can revit make a sequence of renderings ?
riarchitect2012
riarchitect2012 Avatar
4.5 Stars: 25 Votes
I wounder if revit can export a several walkthoughs or make renerders (as to give the order in night and asign a place to save it and go to sleep, then in the morning you will find the work complete. I did that in 3DMAX several years ago , before I switched to revit ....now I miss this option?
another thing  revit 2013  stoped working when I render a 2 linked file, the project is not too huge but yet I can't render the joined files or make a walkthrough , in spite that the PC is core8 AMD , VGA 1 GB, 16 GB Ram ,  GB cash.
Thank you for your support.
Thu, Sep 13, 2012 at 12:55:57 PM | can revit make a sequence of renderings ?
AbsoluteBIM
AbsoluteBIM Avatar
4 Stars: 4 Votes
http://www.revitcity.com/forums.php?action=viewthread&thread_id=28381
Thu, Sep 13, 2012 at 3:17:21 PM | can revit make a sequence of renderings ?
quinn
where is the download for that add in?
Thu, Sep 13, 2012 at 6:51:07 PM | can revit make a sequence of renderings ?
vicozzio
Thank you AbsoluteBIM.
Quinn: The download link is just under the first post isn't it (As an attachment)? the zip file? this link: http://www.revitcity.com/forum_files/111061_Renderviews_1.1.zip ? I haven't download it though.. my employer IT Dept. not allow us to download things.. please confirm if the link above is the right link to download..
Fri, Sep 14, 2012 at 7:40:57 AM | can revit make a sequence of renderings ?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Yes that is the correct link.
Revision sequence
Tue, Sep 19, 2006 at 12:37:41 AM
Drawing List and drawing titleblock with sequence field
Thu, Jun 21, 2007 at 9:11:53 AM
material in renderings
Wed, Dec 12, 2012 at 2:14:22 PM
Customizing Revision Sequence Numbering
Wed, Aug 5, 2009 at 9:51:48 AM
Changing Detail Sequence
Mon, Jul 31, 2006 at 3:35:11 PM
Page generation time: 1.6271
