Forums >> General Discussion >> Revit Project Management >> Creating a custom export layers.txt
Wed, Sep 12, 2012 at 7:16:13 PM | Creating a custom export layers.txt
lawnwrangler13
I want to create a custom export layers.txt that reflects our companies standard for CAD layers. I've tried modifying the AIA Standard.txt file but what is in REVIT doesn't reflect what I put in the text file. Is it possible to change model categories? Naming? Or add to a category. The instructions at the top of the file say
Category <tab> Subcategory <tab> Layer name <tab> color number <tab>
Is it really that easy? It doesn't seem to be. What am I missing?
Tue, May 5, 2015 at 6:33:03 AM | Creating a custom export layers.txt
keroosheh
i have same problem with export, how can export this setup to txt?
How to export CAD with custom subcategory layer
Tue, Feb 15, 2011 at 10:08:37 AM
Export fills to layers
Fri, Sep 11, 2009 at 11:51:47 PM
Export all properties BYLAYER, and create new layers for overrides.
Fri, Nov 14, 2014 at 12:22:28 PM
dwg export
Wed, May 30, 2012 at 1:47:00 AM
exporting to dwg - load layers from standards
Thu, Jul 16, 2015 at 5:24:59 PM
Page generation time: 2.7276
