Forums >> Revit Building >> Technical Support >> WAVE ROOF FAMILY & bracing
Wed, Sep 12, 2012 at 2:27:12 PM | WAVE ROOF FAMILY & bracing
bjwson
2.5 Stars: 3 Votes
Hi All,
i'm using revit 2012 Arch.
i'm in the process of making a Wave shaped roof canopy family. i'm using conceptual Mass fam. template, by drawing the wave shape in South elevation i got it extruded, now my problem is the wave canopy is supported by "X" shaped bracings (20cm x 20cm steel) (see picture) now i need a tip to create the bracings, which are in diagonal & in wave shape, kind off follow the wave curve and yet in diagonal. Any tips to create this shape.
Note: pic's for example only, canopy shape pic (long span facing you)
thx. W
Wed, Sep 12, 2012 at 2:32:00 PM | WAVE ROOF FAMILY & bracing
Those diagonals are on planes.  If you did your extrusion from an elevation, do the "same" with flat planes that zee across the bottom of your roof in that elevation.  Now place your x-brace on those planes.
Wed, Sep 12, 2012 at 3:10:33 PM | WAVE ROOF FAMILY & bracing
bjwson
2.5 Stars: 3 Votes
thx. for the reply. i guess you did not get my point. those brasings are in the wave shape but in other direction of the wave. and they are not bracings but holding the wave.
those pics i attached are examples only,
W
Wed, Sep 12, 2012 at 3:25:34 PM | WAVE ROOF FAMILY & bracing
First their bracings, now their not?  Come on!  An X still exists on a plane.
Edited on: Wed, Sep 12, 2012 at 3:25:54 PM
Edited on: Wed, Sep 12, 2012 at 3:26:22 PM
Wed, Sep 12, 2012 at 3:27:10 PM | WAVE ROOF FAMILY & bracing
Whoops - missed an image.
Wed, Sep 12, 2012 at 11:33:59 PM | WAVE ROOF FAMILY & bracing
mansell5
3.5 Stars: 4 Votes
in the picture youve shown the bracing isnt supporting anything. its just resisting lateral movement or twist.
get your engineer to calculate the member sizes for the "bracing" you show, as its is carrying the roof load.
the connections either end will be interesting !
Thu, Sep 13, 2012 at 1:26:32 AM | WAVE ROOF FAMILY & bracing
bjwson
2.5 Stars: 3 Votes
Hi, May be my English is not so good to explain the situation. pls. find attached the Family i've created and the Image that i am trying achive.
can you see the X-shaped steel that is underside of the canopy (holding it.)
W
Thu, Sep 13, 2012 at 8:42:55 AM | WAVE ROOF FAMILY & bracing
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
The bracing itself is actually curved?
Thu, Sep 13, 2012 at 9:35:03 AM | WAVE ROOF FAMILY & bracing
bjwson
2.5 Stars: 3 Votes
yes. pls.
Thu, Sep 13, 2012 at 10:33:59 AM | WAVE ROOF FAMILY & bracing
I would not call this bracing.  It looks more like a grid to support the material - like a ceiling grid.  I would do it as a texture layer - a material - for 3D.  I have no idea how to do it for 2D.
Thu, Sep 13, 2012 at 11:21:57 AM | WAVE ROOF FAMILY & bracing
quinn
use a pattern based family and create your beam system from it then in your mass model apply the criss cross surface pattern to your bottom of roof andthen apply the paatern you created to it.  See atached image.
Thu, Sep 13, 2012 at 1:30:41 PM | WAVE ROOF FAMILY & bracing
bjwson
2.5 Stars: 3 Votes
very good idea, thx a lot. will try it out for sure.
Mon, Sep 17, 2012 at 4:36:29 AM | WAVE ROOF FAMILY & bracing
#13
bjwson
2.5 Stars: 3 Votes
hi All, here it is. once again thanks for the tip.
Wave Form Curtain Wall & Roof
Tue, Jan 3, 2012 at 9:56:17 AM
Rotation angle of double angle roof bracing.
Mon, Jan 21, 2008 at 2:51:55 PM
Vertical bracing symbolic line ???
Tue, Jun 4, 2013 at 7:33:50 AM
Wall Bracing (plywood sheets)
Sun, Aug 19, 2007 at 7:04:04 PM
Wave Form slab
Fri, Feb 27, 2009 at 8:18:29 AM
Page generation time: 0.8213
