Forums >> Revit Building >> Technical Support >> Is it possible? Convert an AutoCAD 3D Object into a floor
Wed, Sep 12, 2012 at 8:05:24 AM | Is it possible? Convert an AutoCAD 3D Object into a floor
MaeDae315
I am running Revit Architecture 2012.  Currently I am working on a trainstation.
I got in the attached ACAD file from a subcontractor of the platform.  Of course I can link this file into my Revit model and it works, ok.  But, I need this 3D object to be a floor.  I need it to host benches and other platform equipment.  I also need to get the square meters from it and to schedule it.
Any ideas?
Wed, Sep 12, 2012 at 12:45:01 PM | Is it possible? Convert an AutoCAD 3D Object into a floor
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
This article may be helpful for what you are trying to accomplish.
http://autodesk-revit.blogspot.com/2007/11/importing-3d-dwgs-into-revit.html
Wed, Sep 12, 2012 at 2:33:59 PM | Is it possible? Convert an AutoCAD 3D Object into a floor
MaeDae315
Thanks for the link.  I have actually already read this post. :-)
I have done just what the author suggests.  However, I cannot skin the model with a floor.
I can make it into a roof or add walls but no floor.  It wants to make floors within the volume.
I know I could go in an make all the families I want to host to this object into roof hosted familes, but that is silly.
Any other suggestions?  Thanks! :-)
Wed, Sep 12, 2012 at 6:31:14 PM | Is it possible? Convert an AutoCAD 3D Object into a floor
quinn
You already try sketching the floor of the profile first, then use a in-place model void to carve out the bottom of it? When your done you can group the void and floor together so they move as one.
Edited on: Wed, Sep 12, 2012 at 6:32:23 PM
2D DWG Convert to 2D Revit
Mon, Nov 23, 2015 at 1:57:38 PM
How 2 convert more number of Revit (*.rvt) to AutoCAD(*.dwg) files @ a time
Fri, Aug 28, 2009 at 6:40:58 AM
Default how to convert autocad blocks (inserts) into components (family instan
Fri, Nov 9, 2007 at 5:12:51 PM
Btween program convert files
Sun, May 21, 2006 at 5:29:41 PM
import acad 3d objects and convert to Revit
Tue, May 24, 2005 at 8:48:46 PM
Page generation time: 3.2355
