Forums >> Revit Building >> Technical Support >> Revit 2012 Schedules - Filter by DETAIL NUMBER
Tue, Sep 11, 2012 at 11:15:31 AM | Revit 2012 Schedules - Filter by DETAIL NUMBER
mjhunton8836
A similar post was dated for 2009 with no response. Does anyone know how to set up a schedule "field" that would be a view's detail number. I want to be able to see a schedule with the "view name" which is already a field with its "detail number" right next to it. This far, I have had no luck.
Thanks!
Tue, Sep 11, 2012 at 11:52:16 AM | Revit 2012 Schedules - Filter by DETAIL NUMBER
Did you use view list?
Tue, Sep 11, 2012 at 11:58:23 AM | Revit 2012 Schedules - Filter by DETAIL NUMBER
mjhunton8836
I did. Referencing the image you posted, essentially what I need is a "field" that would then put on the schedule DETAIL NUMBER. I definitely understand the field with the sheet number, but I need the number of the VIEW on the SHEET.
Thanks!
Tue, Sep 11, 2012 at 12:25:19 PM | Revit 2012 Schedules - Filter by DETAIL NUMBER
Sorry - I missread your original question.  I think this has come up before.  It is surprising that this field is not available because the information is in the database - the same as the sheet number.  I suggest you put this on the AUGI maintained wishlist.
Elevation Tag Mark (the circle) does not filter
Tue, Oct 16, 2012 at 1:55:49 PM
Linking Details to Schedules
Thu, Mar 14, 2013 at 11:40:23 AM
View Schedule with Sheet Number & Detail Number
Thu, Sep 1, 2016 at 12:07:37 AM
Elevation detail number position
Wed, Oct 13, 2010 at 10:35:41 AM
the correct way to filter out elevations
Thu, Apr 4, 2013 at 4:23:01 PM
Page generation time: 1.8776
