Forums >> Revit Building >> Technical Support >> MEDIUM SCALE FILL COLOR AND PATTERN
Tue, Sep 11, 2012 at 5:16:07 AM | MEDIUM SCALE FILL COLOR AND PATTERN
amolese
How do you modify medium scale fill color and pattern in Revit for an object, say for example I want to show the wall pattern of a brick in Medium Scale Fill Color as Diagonal Cross Hatch but the background color as white. In the example below when I try to edit the background color of the wall I only have access to the Coarse Scale Fill Color but I want to have my wall display the proper hatches that represent them but against a white background not a grey background as shown. How do I go about that? Anyone?
Tue, Sep 11, 2012 at 5:37:37 AM | MEDIUM SCALE FILL COLOR AND PATTERN
amolese
I will like the internal walls with their proper hatches on a white backgound while the external walls (cavity walls, also with their proper hatches) will be on a grey background.
Tue, Sep 11, 2012 at 7:06:12 AM | MEDIUM SCALE FILL COLOR AND PATTERN
amolese
SORTED! I went into the edit type properties of the wall assembly and edited the shaded appearance to be white. Thanks to those who read this thread.
Topo coarse scale fill color
Fri, Jun 15, 2007 at 10:00:13 AM
Scaling fill pattern
Thu, Nov 17, 2011 at 4:01:24 PM
color scheme/fill pattern
Mon, Jul 9, 2012 at 4:56:36 AM
Material Fill Pattern Scale
Mon, Nov 16, 2009 at 12:53:40 PM
Existing Walls with Coarse Fill Pattern Revit 2008
Wed, Aug 13, 2008 at 3:28:01 PM
Page generation time: 0.3263
