Forums >> Revit Structure >> Technical Support >> "hidden Line" Visual style becomes wireframe with CAD file
Mon, Sep 10, 2012 at 12:21:01 PM | "hidden Line" Visual style becomes wireframe with CAD file
ghanlon
I am using Revit 2013.  I am working in a file that has a CAD file in it.  When I am in a view where the CAD file is visible, the whole view becomes wireframe.  It took me a long time to figure out the CAD file is the variable that is changing it but i have no idea why it would do that. Is anybody else noticing this? Is it a feature or a glitch?
Thanks
Mon, Sep 10, 2012 at 8:15:10 PM | "hidden Line" Visual style becomes wireframe with CAD file
mhans
3 Stars: 10 Votes
It could be a number of reasons. Is the cadfile linked? You said 2013, is your graphics card supported? Does the cadfile change only on plan view ?...3d view?
Motto: "No Post left behind"
Mon, Sep 10, 2012 at 10:34:07 PM | "hidden Line" Visual style becomes wireframe with CAD file
Thread Post Kudo! #3
Warchitect
4 Stars: 5 Votes
type HIDE and you get it hidden line view.
Tue, Sep 17, 2013 at 3:10:14 PM | "hidden Line" Visual style becomes wireframe with CAD file
RyanJavlyn
I know that this is an old thread, but I recently came across this same issue.  Whenever a view is showing the linked AutoCAD file that I am using, everything gets forced to wireframe view type and lines will no longer show as hidden.
Tue, Sep 17, 2013 at 3:21:06 PM | "hidden Line" Visual style becomes wireframe with CAD file
When you have problems like this, you need to include the Revit release you are using and your update status.
My first answer would be if you are using 2014 - then you must have update 1 also installed.
My second answer is - Is your video card in the compatable list?  Turn off hardware acceleration and see what happens.
Tue, Sep 17, 2013 at 3:28:10 PM | "hidden Line" Visual style becomes wireframe with CAD file
RyanJavlyn
Revit 2013.  Hardware acceleration is already off.  My video card is not "on the list".
Tue, Sep 17, 2013 at 3:29:15 PM | "hidden Line" Visual style becomes wireframe with CAD file
RyanJavlyn
By the way... I'm using Revit 2013 Update Release 2
Wed, Feb 12, 2014 at 10:20:30 AM | "hidden Line" Visual style becomes wireframe with CAD file
jaylexlites86
one of my elevations and 3D view showed as wireframe when it was under Hidden view setting.
I solved the problem by un-linking my CAD files, and then go to the problematic views, under view property, visibility/graphic overrides, imported categoreis tab, un-check all items.
Mon, Feb 24, 2014 at 9:14:42 PM | "hidden Line" Visual style becomes wireframe with CAD file
rumighazali
I have the same problem & solved, I just deleted 3D view then load new 3D view again.
Fri, Mar 7, 2014 at 10:09:53 AM | "hidden Line" Visual style becomes wireframe with CAD file
RyanJavlyn
Just as a follow up on this topic... The issue has not been resolved with Revit 2014.  The easiest workarounds for this problem are to unlink the AutoCAD file or to just hide the the AutoCAD file in the view that you are working in.  That seems to solve the issue every time.
Mon, Dec 22, 2014 at 1:23:15 PM | "hidden Line" Visual style becomes wireframe with CAD file
LRSRender
Delete the view then re-create it.
We see this every so often with 3D views.
Mon, Feb 28, 2022 at 3:04:02 AM | Warchitect
derenik2578
Quoting Warchitect from 2012-09-10 22:34:07
God Bless you! Solved mine Smile needed a real quick sollution . thanks
Color in Hidden Line Visual Style??
Mon, Oct 19, 2015 at 12:16:53 PM
Hatch and background in hidden line visual style
Wed, Nov 10, 2010 at 10:02:09 AM
RAC 2012 - Structural Section View shows as Wireframe vs. Hidden Line
Wed, Mar 7, 2012 at 1:50:31 PM
Wireframe display error
Wed, Feb 20, 2008 at 4:02:37 PM
Hidden Line View [ 1 2 ]
Wed, Oct 6, 2010 at 2:49:02 AM
22
Page generation time: 1.1902
