8 Users Online (6 Members):
Forums >> Revit Building >> Technical Support >> Revit Arch 2013 - Roof - Starts at first floor level and second floor level
6 Posts No Rating |
Hi! I am working on a home plan where the roof design has one side of the gable roof at the second floor level and the other side of the gable starting on the first floor level. See attached sketch. How do you design this type of roof with Revit Architecture 2013? This roofline is similar to a salt box design.
Thanks!
Rob
Edited on: Sun, Sep 9, 2012 at 7:59:58 PM
Change you eave height when editing roof line, or you can use 2 roofs
Look at the properties of any roof sketch line. Not only can it be slope defining but you can set where it is in relation to your roof. So if your roof is defined from the high eave, just set that lower roof edge where as a negative from that level.
Site Elevation to Floor Level Problem |
Wed, Jun 27, 2012 at 11:42:30 AM
Strangest Revit Floor Plan / Level Problem - Not a newbie question |
Wed, Oct 4, 2017 at 1:59:11 PM
Changing model constraints from one level to another |
Wed, Aug 12, 2015 at 3:29:36 PM
Revit 8 -First Floor Roof Adjacent Second Floor Walls |
Sun, Oct 1, 2006 at 7:57:59 PM
Floor Plan associated to wrong level... |
Fri, Jul 2, 2021 at 3:23:05 PM
