Forums >> Revit Building >> Technical Support >> Family Void cutting through two elements in a project?
Fri, Sep 7, 2012 at 9:29:08 PM | Family Void cutting through two elements in a project?
quinn
Is there a way to have a void within a family that when loaded into a project will cut through multiple different types of elements?  For example a void that cuts through a wall and millwork?  I tried using a face based void with the (cuts with voids when loaded) checked so it cuts within the project but it only cuts the element it is hosted from and nothing else.
Edited on: Tue, Sep 11, 2012 at 2:56:32 PM
Tue, Sep 11, 2012 at 2:48:19 PM | Family Void cutting through two elements in a project?
The only way you can cut multiple objects would be an in-place void.  And there are still some objects that may not be cut.
Tue, Sep 11, 2012 at 2:55:56 PM | Family Void cutting through two elements in a project?
quinn
It looks like the parameter check box for (cuts with voids when loaded) is for the project but only effects elements of the same family category.
Wall Hosted Family cutting void into Wall
Mon, Aug 23, 2010 at 3:58:59 PM
Is there a way to exclude what a void cuts into?
Wed, Oct 23, 2013 at 10:42:00 AM
Void cutting floor problem
Mon, Nov 12, 2018 at 10:01:17 AM
Void extrusion family visibility
Fri, Apr 22, 2022 at 7:57:52 AM
void extrusion not cutting solid extrusion
Fri, Oct 10, 2008 at 3:47:43 PM
Page generation time: 1.0062
