Forums >> Revit Building >> Tips & Tricks >> Stair landing question
Thu, Sep 6, 2012 at 3:41:04 PM | Stair landing question
CDWdavid
5 Stars: 5 Votes
I would like to design a 14'-0" high straight run stair, the landing will be at 8'-6". The first flight will have 15 risers at 6.80"; the second flight 10 risers at 6.60". The only way that I can do in Revit was, created two stairs with a floor (landing) in between. Please see attached picture. If I'm following Revit's way, it would have 24 risers at 7".
Does any body can help me to hide those joint lines, as shown on attached drawing? Or if I missed something in Revit which can allow me to do exact what I wished.
Thanks!
Thu, Sep 6, 2012 at 3:49:40 PM | Stair landing question
First - Revits way doesn't mean you have to have 7".  If you want 25 risers instead of 24 - then just lower your max riser height and you'll have it.  Just strech out the first 15 risers, then the landing, then the remaining risers.
We typically never alter riser heights in stairs.  Is your landing at a fixed level that you must hold to?  If so, then you have no other solution other than what you ahve done.
Editing Profile of Stair Landing
Mon, Mar 3, 2014 at 2:36:37 PM
Starting a Rail on the stair landing.
Thu, Dec 19, 2013 at 3:01:59 PM
Stair Landing Height Problem
Fri, May 13, 2016 at 12:33:14 PM
landing trouble - jog in landing
Tue, Feb 28, 2017 at 6:16:04 PM
Stair to landing connection shown incorrect in section
Mon, Sep 20, 2010 at 11:40:14 AM
Page generation time: 1.6605
