Forums >> Revit Structure >> Technical Support >> I can see through the floor ??
Wed, Sep 5, 2012 at 7:30:50 AM | I can see through the floor ??
MariaDTU
4 Stars: 1 Votes
How do I fix så I dont see through the floor like in the picture?
Thnaks from Maria
Wed, Sep 5, 2012 at 7:32:38 AM | I can see through the floor ??
???  I don't think you are seeing through the floor.
Wed, Sep 5, 2012 at 7:50:27 AM | I can see through the floor ??
MariaDTU
4 Stars: 1 Votes
I'm and allso through the wall but it is only some things
Wed, Sep 5, 2012 at 8:07:33 AM | I can see through the floor ??
If these things should truely be hidden, then there may be another problem.  If any part of a non-cutable family is cut by the view plane, the entire family shows.  That includes invisible lines in the family.  I suggest you look at the families and see if that may be your problem.  Search "cutable" in your HELP.
Wed, Sep 5, 2012 at 8:34:18 AM | I can see through the floor ??
MariaDTU
4 Stars: 1 Votes
But they are not suposest to be hiden, but they are inside the room. ?
Wed, Sep 5, 2012 at 8:57:53 AM | I can see through the floor ??
Sorry but I can't help you more until you do some work on your own.  I pointed you at a potential problem.  Look at that or at least be more descriptive about your objects.  For all we know, these could be behind the camera instead of below the floor.  Look at the properties of the objects.
Ground Floor info. appearing on Second Floor
Thu, Jun 9, 2016 at 2:24:40 PM
floor sketching
Tue, Aug 26, 2008 at 3:35:49 PM
(Dumb question) Can't see first floor when in second floor view [Revit 2015]
Thu, Jul 16, 2015 at 6:11:13 PM
First floor slab or ground floor ceiling?
Fri, Aug 30, 2013 at 7:41:03 AM
RAC 2010 Structural Floor V Floor - Whats the difference
Tue, Jul 27, 2010 at 8:35:33 AM
Page generation time: 0.2470
