Forums >> Revit Building >> Technical Support >> Student version of Revit 213 runs slow on new laptop
Fri, Aug 31, 2012 at 6:31:58 PM | Student version of Revit 213 runs slow on new laptop
forthright
I just downloaded the student version of Revit Architecture 2013 to my new lap top.  The program runs very slowly, pausing several seconds each time I try to rotate the model.  My machine has 6 GB of memory, an i3 processor, running Windows 7 Home Premium, 64 bit.  It should have the ability to easily run Revit.  Any ideas what could be causing the problem?
Thanks.
Sat, Sep 1, 2012 at 4:58:17 AM | Student version of Revit 213 runs slow on new laptop
4 Stars: 205 Votes
Well it's not the best but it's a decent machine, what's the file size of your model?
Sat, Sep 1, 2012 at 7:20:10 AM | Student version of Revit 2013 runs slow on new laptop
forthright
The file size is about 15MB.  But the same thing happens with the sample architecture project that comes pre-loaded with Revit.  It's only 6.6 MB.
Sat, Sep 1, 2012 at 7:28:08 PM | Student version of Revit 213 runs slow on new laptop
hugh
3.5 Stars: 4 Votes
What is the laptop make and model?
Could be the graphics hardware is struggling a bit.
Hugh Adamson
www.hatchkit.com.au
Sat, Sep 1, 2012 at 10:34:53 PM | Student version of Revit 213 runs slow on new laptop
forthright
The laptop is a Samsung NP300EA5.  Thanks.
Sat, Sep 1, 2012 at 11:35:36 PM | Student version of Revit 213 runs slow on new laptop
hugh
3.5 Stars: 4 Votes
Couldn't find that exact model online but there's some NP300 E5A all having GeForce (with Optimus) or Radeon GPUs.
Could be you need to enable the dedicated graphics via a BIOS setting or by running a graphics driver utility - some lappies allow you to constantly run onboard Intel shared graphics to save power and only enable the faster GPU when mains power is available or if you explicitly set it on.
Best of luck.
Hugh Adamson
www.hatchkit.com.au
re-downloading Revit student version
Fri, Feb 19, 2010 at 12:23:08 PM
I cant remove the student version
Fri, Feb 17, 2012 at 6:51:46 AM
File in Student Version transfers to Professional Version
Mon, Jul 26, 2010 at 12:06:11 PM
Revit Sheet Sets-Student Version
Fri, Apr 22, 2016 at 5:45:59 PM
revit student version
Mon, Oct 5, 2009 at 3:23:39 PM
Page generation time: 1.4129
