24 Users Online (22 Members):
Forums >> Revit Building >> Technical Support >> Element Graphic Override 2013 - Transparency
4 Posts No Rating |
When I make a family have 100% surface transparency I can see the outlet behind the equipment family on the screen. When I print the elevation the outlet does not show. In 2012 I was able to make a piece transparent, is that not possible anymore, or where did it move to.
I don't think its a transparency issue if it only dissappears when printed. what if you try toggling between Vector and Raster printing; any difference?
4 Posts No Rating |
It does look like it will appear if it is a raster, but the same condition worked fine in 2012 if I could make the family transparent.
Help: Print transparent objects from floor plan view to pdf in revit 2013 |
Tue, May 8, 2012 at 2:49:41 PM
CURTAIN GRID BASED ELEMENTS CANNOT BE GROUPED |
Tue, Oct 28, 2014 at 12:55:23 PM
Transparency Phase Override & Rail Preview |
Tue, Apr 7, 2009 at 10:44:23 AM
Dual Phase Graphic Override? |
Tue, Apr 28, 2009 at 9:23:26 AM
material transparency in elevation views |
Fri, Apr 1, 2016 at 3:17:41 PM
