Forums >> Revit Building >> Technical Support >> Autocad Template file to title block
Wed, Jan 11, 2006 at 1:08:56 AM | Autocad Template file to title block
jyothi
hi, How do we convert Autocad template file as Revit titleblock. i am trying to import but it is giving me error. Thanks,
Wed, Jan 11, 2006 at 3:45:38 PM | RE: Autocad Template file to title block
sfrazier
If I am understanding you correctly, you want to import a dwt file into revit that has your titleblock on it? If so, try importing a dwg with the title block on it. Sorry if I am miss understanding.
Wed, Jan 11, 2006 at 4:48:24 PM | RE: Autocad Template file to title block
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Just some guidelines. I'd only import the dwg to use as an element to sketch over using revit lines. Don't explode it. Use it then delete it out of the titleblock. Make sure you have current view only ticked when importing the dwg. What error message are you receiving?
Wed, Jan 11, 2006 at 11:30:12 PM | RE: Autocad Template file to title block
jyothi
hi, sfazier, ya ur right i wanted to import dwf file in title block. Mr Spot, i tried it as dwg also but even after importing it was not seen in view, i have imported in current view only,checked with all visibilty settings, but still i am not able to see the dwg file in title block. is it something to do with autocad file? it is 24x36 sbeet in autocad also. waiting for reply. Thanks,
Thu, Jan 12, 2006 at 1:45:32 AM | RE: Autocad Template file to title block
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Check you have the appropriate scale when importing. If you zoom right out and do a window selectiong does it select the dwg?
Thu, Jan 12, 2006 at 11:30:24 AM | RE: Autocad Template file to title block
sfrazier
jyothi, Firstly, in order for you import a dwf file you have 8.1. and you need to load the markup instead of importing... What you are looking for to do so is in the import menu at the bottom.... RE:DWG I had a simiilar situation happen. Here's a couple of things to try... #1- Mr. Spot is right, what you want to do is check the scale of the title block in ACAD. Best thing to do for novice CAD users is to paste or put the title block in Paper space. If the title block is in paper space you have a good idea of it's "real" dimensions. Next scale it, explode it then import that into a title block tempate in revit (.rte). I have found that sometimes revit will not except nested blocks, attributes very well, and there's other times were it has. Use the cad title block as a reference to trace. #2- Another option is to check your importing properties ensure they are set to the right scale. Often times - Revit will not "automatically scale your dwg correctly" I would just tell it to import in inches in the import dialogue menu. Once it is in and you don't see it, zoom out as far as possible and select the whole area (cross select). Check your filter and see if you have the dwg selected and immediately go to scale. If the scales are off it may be too small for you to have seen and needed to rescaled. Hope one of these options help you... Let us know if you resolved it and what worked... Shaun
Mon, Jan 16, 2006 at 12:02:50 AM | RE: Autocad Template file to title block
jyothi
hi, Thanks a lott for both of you,Shaun and Mr Spot U guys were right the autocad drawing scale and what it measured was differnt.i scaled autocad drawing and imported again and it worked ver well !!!. Thanks again. look forward for your valuable time in future also.
How to import my title block from AutoCAD?
Mon, Sep 10, 2007 at 4:25:43 PM
12
Title block, not the usual question
Wed, May 9, 2012 at 8:56:38 AM
Help, Title block scale appear to be wrong and can not be changed
Mon, Aug 29, 2016 at 10:56:37 AM
How to link a Revision Schedule on Title sheet with Title Block
Fri, Jan 11, 2013 at 7:26:26 AM
Title Block Images
Wed, Sep 22, 2010 at 3:15:45 PM
Page generation time: 2.0344
