Forums >> Revit Building >> Technical Support >> pipes showing up as lines
Thu, Aug 30, 2012 at 3:42:04 AM | pipes showing up as lines
frifer
5 Stars: 4 Votes
hi guys!
i am trying to place pipes but for some reason they show up as a single line, and in some views they are totally invisible.
i tried also to make some changes in diameter but nothing changed.
and when i am on the top view i am only able to go in one direction and cant make 90° bends.
what is wrong?
thanks
Igor
Check out my new Renderlist add-in to render multiple views in sequence overnight! Get it here and remember to leave some feedback Shadey http://www.revitcity.com/forums.php?action=viewthread&thread_id=28381
Thu, Aug 30, 2012 at 3:46:08 AM | pipes showing up as lines
4 Stars: 205 Votes
Are you in MEP? I don'tr work in MEP but did you change that view to "medium or fine" in the view mode?
Thu, Aug 30, 2012 at 3:50:03 AM | pipes showing up as lines
frifer
5 Stars: 4 Votes
uhm, i have the suite, and that includes revit. but i don't read "MEP" anywhere. lines are not set to fine. i also noticed that i can only draw the first section of line, then i cant continue to draw anything...
Thu, Aug 30, 2012 at 4:57:58 AM | pipes showing up as lines
frifer
5 Stars: 4 Votes
just reinstalled, didnt help.. Sad
Thu, Aug 30, 2012 at 6:04:29 AM | pipes showing up as lines
4 Stars: 205 Votes
You have Revit Architectural, Structural and Mechanic, Electrical and Plumbing (MEP), I don't know what version are you working on, that's why I asked if you are working in MEP.
Did you change the "Visual" style mode to "Medium or Fine" and check if that solved the problem?
Thu, Aug 30, 2012 at 6:06:17 AM | pipes showing up as lines
frifer
5 Stars: 4 Votes
yes tried that too! i am making a video and uploading it to youtube to show the problems.
Thu, Aug 30, 2012 at 6:20:22 AM | pipes showing up as lines
frifer
5 Stars: 4 Votes
here we go.. http://www.youtube.com/watch?v=nCO0HdBcvrk&feature=youtu.be looks like the system families are not loaded correctly..
Thu, Aug 30, 2012 at 6:53:36 AM | pipes showing up as lines
I don't use MEP.  Is this a coarse / fine issue.  I bet it is.
Thu, Aug 30, 2012 at 7:21:47 AM | pipes showing up as lines
frifer
5 Stars: 4 Votes
i dont think so because of several reasons:
a) i can only draw the first line, then no more line is drawn when i click. (in the video i am actually clicking all around when i move the mouse)
b) no family is loaded or available (as you see on the clip when i hit on the right)
c) i tried to click the fine/coarse button several times but with no result...
Thu, Dec 4, 2014 at 10:00:29 PM | pipes showing up as lines
willyharbs
To have the pipes show up as the actual 3d form, you need to have the detail level of the view set to FINE
or you can set just the pipe catogory to FINE in the visibility/graphics override or view template if your using one.
Can we convert lines to pipes? (Revit MEP)
Tue, Aug 28, 2007 at 9:26:18 AM
Duo pipes - Twin pipes for central heating
Wed, Jan 16, 2019 at 3:48:53 PM
pipes won't show up...
Mon, Jun 15, 2009 at 1:36:08 PM
Linked CAD ducts/pipes not showing up in Revit Structure 2013
Fri, Jul 10, 2015 at 8:36:42 AM
13
Model In Place showing when out of view range?
Fri, Jun 19, 2015 at 8:35:35 AM
Page generation time: 0.4101
